BT.com
Wishlist
BenQ GL2450HM 24" 1920x1080 5ms HDMI DVI-D LED Monitor
Delivery
Standard Due date unavailable
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12000000: 1, speakers, response time of 2 ms and DVI and HDMI connector, this 24" 16:9 LED monitor delivers you the audiovisual enjoyment.
BenQ GL2450HM - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Glossy black
57.9 cm x 17.9 cm x 43.6 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
TCO Displays 5.0
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable - VGA to VGA
TCO Displays 5.0
Power Supply
Internal
42 Watt
Power Consumption Stand by / Sleep
0.3 Watt
0.3 Watt
On / Off Switch
No
EPEAT Compliant
EPEAT Silver
Scroll to top
