BT.com
Wishlist
BenQ GL2450HM 24" 1920x1080 5ms DVI HDMI VGA LED Monitor
BenQ GL2450HM 24" 1920x1080 5ms DVI...
£109.72
More than 50 in stock
£109.72
Add to wishlist
Delivery
Standard 1-3 working days
The GW2470H VA LED monitor brings viewing pleasure to everyday work and play with exquisite details on the exterior and striking visual performance delivered by 3000:1 high contrast ratio, 178°/178°wide-viewing angle, dual HDMI and BenQ's eye-caring design, which consists of BenQ's flicker-free technology and low blue light modes.
BenQ GW2470H - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
16 ms (tr - tf); 4 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Black texture, glossy black
55.3 cm x 18.9 cm x 42.5 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Dynamic Power Saving (DPS), Low Blue Light Mode, 8-bit gamma
55.3 cm x 18.9 cm x 42.5 cm - with stand
4 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot, Flicker-free technology
Stand
1 x HDMI cable , 1 x VGA cable
TCO Displays 6.0
AC 120/230 V
23 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 55.3 cm - depth: 18.9 cm - height: 42.5 cm - weight: 4 kg , Without stand - width: 55.3 cm - depth: 5.1 cm - height: 32.9 cm
Limited warranty - 3 years
Accessories
£7.69
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£22.29
£42.00
£57.43
£20.60
Scroll to top
