BT.com
Wishlist
BenQ GL2450HE 24" 1920x1080 2ms HDMI DVI Black Monitor
Delivery
Standard Due date unavailable
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M: 1, Senseye Human Vision technology, 5 ms response time and DVI connector, this 24"W 16:9 LED monitor delivers every image detail with the best viewing quality.
BenQ GL2450HE - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Shiny black
57.9 cm x 17.9 cm x 43.7 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV Bauart, TCO Displays 5.2
2 years warranty
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, phase
HDCP, Senseye 3 Technology
Shiny black
57.9 cm x 17.9 cm x 43.7 cm - with stand
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
AC 90 - 264 V (47 - 63 Hz)
22 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 57.9 cm - depth: 17.9 cm - height: 43.7 cm - weight: 4.1 kg , Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35.1 cm
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
5 °C
20 - 90%
Scroll to top
