BT.com
Wishlist
BenQ GL2450E 24" 1920x1080 5ms DVI VGA Monitor
Delivery
Standard Due date unavailable
Enjoy the revolutionary picture quality with the BenQ LED monitor GL2450E! Built with an LED backlight panel, the stylish GL2450E comes with an ultra-high dynamic contrast ratio of 120,000:1, 16:9 100% dot-to-dot image quality, and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times.
GL2450E is not only adding visual performance to your workstation and living space, but also bringing you a harmony of visual elements. The breakthrough layering design comes with clearly sculptured countenance, boldly terraced contour, as well as oval base stand which electively reduces impressions of bulkiness. The textured front bezel also minimizes the visual discomfort the bezel glare may cause.
BenQ GL2450E - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
57.93 cm x 17.91 cm x 43.64 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Eco-Mode, Senseye 3 Technology
Glossy black
4.1 kg
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
AC 120/230 V
34 Watt
Power Consumption Sleep
0.3 Watt
Scroll to top
