BT.com
Wishlist
BenQ GL2450 24" 1920 x 1080 5ms DVI VGA Monitor
BenQ GL2450 24" 1920 x 1080 5ms DVI...
Last Few Remaining
£126.58
Last Few Remaining
Price Drop
Clearance
Price Drop!
22 in stock
£126.58
Add to wishlist
Delivery
Standard 1-3 working days
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, Senseye Human Vision technology, 5ms response time and DVI connector, this 24" W 16:9 LED monitor delivers every image detail with the best viewing quality.
BenQ GL2450 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
57.9 cm x 17.9 cm x 43.6 cm
4.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.0, TUV Rh
3 years warranty
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour balance, saturation, gamma correction, graphic / text mode, colour temperature, phase, clock, hue
HDCP, 72% colour gamut, Senseye Human Vision Technology, Senseye 3 Technology, Flicker Free technology, ecoFACTS Label
Glossy black
4.1 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x power cable , 1 x VGA cable
Power Supply
Internal
AC 90 - 264 V
34 Watt
Power Consumption Stand by
0.3 Watt
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Accessories
£8.12
£9.08
£15.18
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.80
£9.48
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£43.12
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.61
£58.10
Scroll to top
