BT.com
Wishlist
BenQ GL2450 - LED monitor - 24" - 1920 x 1080 FullHD - 2 ms - DVI-D, VGA - glossy black
BenQ GL2450 - LED monitor - 24" -...
£133.88
Select:
£133.88
Add to wishlist
Delivery
Standard Due date unavailable
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, Senseye Human Vision technology, 5ms response time and DVI connector, this 24" W 16:9 LED monitor delivers every image detail with the best viewing quality.
BenQ GL2450 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
57.9 cm x 17.9 cm x 43.6 cm
4.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.0
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye 3 Technology
Glossy black
4.1 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
TCO Displays 5.0
Power Supply
Internal
34 Watt
Power Consumption Stand by / Sleep
0.3 Watt
0.3 Watt
ENERGY STAR Certified
Scroll to top
