BT.com
Wishlist
BenQ GL2250HM 21.5" 1920x1080 2ms DVI HDMI LED Monitor
BenQ GL2250HM 21.5" 1920x1080 2ms...
£102.34
£102.34
Add to wishlist
Delivery
Standard Due date unavailable
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2250HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1, speakers, response time of 2ms and DVI and HDMI connector, this 21.5"W 16:9 LED monitor delivers you the audiovisual enjoyment.
BenQ GL2250HM - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (typical); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
52.3 cm x 17.4 cm x 40 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 5.0
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
21.5"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye Human Vision Technology, Senseye 3 Technology
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, K-lock security slot
1 x VGA cable
TCO Displays 5.0
Power Supply
Internal
30 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Scroll to top
