BT.com
Wishlist
BenQ GL2250 - LCD display - TFT - LED backlight - 21.5" - widescreen - 1920 x 1080 -  glossy black
BenQ GL2250 - LCD display - TFT -...
£84.46
Select:
Hurry, only 1 left in stock!
£84.46
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Thursday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Whether you're catching up on the Internet or viewing documents, the BenQ GL2250 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12,000,000:1, Senseye Human Vision technology, 5 ms response time and DVI connector, this 21.5" 16:9 LED monitor delivers every image detail with the best viewing quality.
BenQ GL2250 - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Power Consumption (On mode)
24 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (rise+fall); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
52.5 cm x 17.4 cm x 40 cm
3.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
TUV Bauart, TCO Displays 5.1
Display Type
24 W
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye 3 Technology
Glossy black
3.7 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Power Supply
Internal
AC 90 - 260 V (47 - 63 Hz)
Power Consumption Stand by / Sleep
0.3 Watt
0.3 Watt
EPEAT Compliant
EPEAT Silver
5 °C
20 - 90% (non-condensing)
Scroll to top
