BT.com
Wishlist
BenQ GL2070 19.5" 1600x900 5ms DVI-D LED Monitor
BenQ GL2070 19.5" 1600x900 5ms...
£86.96
Hurry, only 1 left in stock!
£86.96
Add to wishlist
Delivery
Standard 1-3 working days
GL2070 LED featuring a dynamic ratio of 12M:1, 5ms response time and DVI connector, this 19.5"W LED monitor delivers every image detail with the best viewing quality.
BenQ GL2070 - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Textured black, glossy black
46.2 cm x 18.9 cm x 38.6 cm
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
120
Backlight Technology
LED backlight
HDCP, 72% colour gamut, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology
46.2 cm x 18.9 cm x 38.6 cm - with stand
DVI , VGA (HD-15)
Mechanical
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Stand
1 x VGA cable
AC 120/230 V
17 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 46.2 cm - depth: 18.9 cm - height: 38.6 cm - weight: 2.99 kg , Without stand - width: 46.2 cm - depth: 4.93 cm - height: 27.5 cm - weight: 2.41 kg
Scroll to top
