BT.com
Wishlist
BenQ GL2055 20" LED 1600x900 VGA DVI Black
Delivery
Standard Due date unavailable
Whether you're catching up on the show on the Internet or viewing documents, the BenQ GL2055 LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12M:1 and response time of 5 ms, this 20" W 16:9 LED monitor delivers you the visual enjoyment.
BenQ GL2055 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.276 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
49.1 cm x 16.4 cm x 37.1 cm
2.96 kg
Microsoft Certification
Compatible with Windows 7
Display Type
Diagonal Size
20"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.276 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
165 MHz
Horizontal Viewing Angle
+90 / -90
Vertical Viewing Angle
+65 / -65
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
2.96 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+15
PowerSave, K-lock security slot
1 x VGA cable
Power Supply
Internal
16 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Scroll to top
