BT.com
Wishlist
BenQ GL2023A 19.5" 1600x900 5ms VGA Black Monitor
BenQ GL2023A 19.5" 1600x900 5ms VGA...
£70.40
More than 50 in stock
£70.40
Add to wishlist
Delivery
Standard 3-5 working days
Whether you're catching up on the show on the Internet or viewing documents, the BenQ GL2023A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M: 1, response time of 5 ms, and BenQ's exclusive Senseye technology, this 19.5"W 16:9 LED monitor delivers you the visual enjoyment with best value.
BenQ GL2023A - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Glossy black
47.7 cm x 16.5 cm x 35.9 cm
2.9 kg
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
72% colour gamut, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
47.7 cm x 16.5 cm x 35.9 cm - with stand
2.9 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Power Supply
Internal
AC 120/230 V
15 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Microsoft Windows 7, Windows 8
Scroll to top
