BT.com
Wishlist
BenQ GL2023A 19.5" 1600 x 900 5ms LED Monitor
BenQ GL2023A 19.5" 1600 x 900 5ms...
Free delivery
£62.98
Free delivery
Price Drop
Price Drop, Was £68.92
19 in stock
£62.98
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Whether you're catching up on the show on the Internet or viewing documents, the BenQ GL2023A LED monitor is the perfect choice for you! Featuring a dynamic contrast ratio of 12M: 1, response time of 5 ms, and BenQ's exclusive Senseye technology, this 19.5"W 16:9 LED monitor delivers you the visual enjoyment with best value.
BenQ GL2023A - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Glossy black
47.7 cm x 16.5 cm x 35.9 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1600 x 900
Pixel Pitch
0.27 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
72% colour gamut, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
47.7 cm x 16.5 cm x 35.9 cm - with stand
2.9 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
Stand
TCO Displays 6.0
Power Supply
Internal
AC 120/230 V
15 Watt
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 47.7 cm - depth: 16.5 cm - height: 35.9 cm - weight: 2.9 kg , Without stand - width: 47.7 cm - depth: 7.8 cm - height: 35.2 cm
Accessories
C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE
Quicklinx: 63P0 | In Stock
£9.31
£9.81
£9.31
£12.34
Scroll to top
