BT.com
Wishlist
BenQ GC2870H 28" 1920x1080 5ms HDMI LED Monitor
BenQ GC2870H 28" 1920x1080 5ms HDMI...
£178.05
12 in stock
£178.05
Add to wishlist
Delivery
Standard 1-3 working days
The GC2870H VA LED monitor brings viewing pleasure to everyday work and play with exquisite details on the exterior and striking visual performance delivered by wide color gamut, true 8-bit color, 3000:1 high contrast ratio, 178°wide-viewing angle, dual HDMI and BenQ's eye-caring design, which consists of BenQ‘s Flicker-free technology and low blue light modes.
BenQ GC2870H - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
Panel Type
VA
Aspect Ratio
16:9
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Glossy black
65.89 cm x 5.415 cm x 38.13 cm
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
57 kWh
39 W
Diagonal Size
28"
Panel Type
VA
Aspect Ratio
16:9
Pixel Pitch
0.32 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, Senseye Technology, Dynamic Power Saving (DPS), Flicker Free technology, 85% NTSC (CIE 1976) colour gamut
Glossy black
65.89 cm x 5.415 cm x 38.13 cm - without stand
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
K-lock security slot
1 x VGA cable - 1.5 m , 1 x HDMI cable - 1.5 m
AC 120/230 V
38 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 65.89 cm - depth: 20.367 cm - height: 47.68 cm , Without stand - width: 65.89 cm - depth: 5.415 cm - height: 38.13 cm
ENERGY STAR Certified
Scroll to top
