Click to visit BT.com
BT.com
Wishlist
BenQ G702AD 17" 5MS 1280 x 1024 LCD Monitor
Quicklinx: 7DTBWS00
Mfr#: 9H.L3.FLB.Q8U
Essential accessories
Senseye+Photo Image technology brings you the most optimized images. This exclusive technology of BenQ G702AD gives you five pre-set modes fitting to your everyday viewing needs! What is more, you can now access them through the Q-Pilot - BenQ's very own on-screen display manager.
BenQ G702AD - LCD monitor - 17"
LCD monitor - 17"
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
700:1 / 2000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
37 cm x 13.7 cm x 37 cm
3.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
RoHS
Display Type
LCD monitor / TFT active matrix
Diagonal Size
17"
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Controls & Adjustments
Colour temperature
Senseye+Photo Image Technology
3.4 kg
VGA
Mechanical
Tilt
Tilt Angle
25
Flat Panel Mount Interface
100 x 100 mm
Wall mountable
1 x VGA cable
RoHS
Power Supply
Internal
35 Watt
Power Consumption Stand by / Sleep
1 Watt
EPEAT Compliant
EPEAT Silver
