BT.com
Wishlist
BenQ EX3200R 31.5" 1920x1080 4ms HDMI LED Curved Monitor
BenQ EX3200R 31.5" 1920x1080 4ms...
£486.85
£486.85
Add to wishlist
Delivery
Standard 1-3 working days
Video enjoyment has never been better. Treat your eyes to an immersive time with BenQ's EX3200R, a 31.5 inch Curved Entertainment Monitor. Designed to have a curvature of 1800R to increase your field of view, matched with Cinema Mode and Video Format support, movie enthusiasts can enjoy a more cinematic experience.
BenQ EX3200R - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class A
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
38 W
Curved Screen
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 144 Hz, HDMI: 76 Hz)
Pixel Pitch
0.12125 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, tilt
Grey
72.737 cm x 22.373 cm x 52.952 cm
9.1 kg
2 years warranty
Display Type
Energy Class
Class A
54 kWh
38 W
Diagonal Size
31.5"
Curved Screen
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.12125 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
45 - 144 Hz
Horizontal Refresh Rate
30 - 167 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 5700K
Picture in picture, HDCP, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Picture Mode, Cinema Mode, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, FreeSync Technology, sRGB Color Space
Grey
9.1 kg
HDMI , DisplayPort , Mini DisplayPort , Headphones
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
60 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x HDMI cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
AC 90 - 264 V (47 - 63 Hz)
48 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
5 °C
20 - 90% (non-condensing)
Scroll to top
