BT.com
Wishlist
BenQ EW3270ZL 32" 2560x1440 4ms HDMI LED Monitor
BenQ EW3270ZL 32" 2560x1440 4ms...
£469.29
£469.29
Add to wishlist
Delivery
Standard 1-3 working days
Featuring an AMVA+ panel, the 32 inch LED monitor incorporates Brightness Intelligence technology to optimize the display performance for multimedia enjoyment. Experience visual comfort during extended viewing with BenQ's Eye-care technology which includes Low Blue Light Plus mode and Flicker-free technology. Slim bezel design beautifully complements any space.
BenQ EW3270ZL - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
73 kWh
Power Consumption (On mode)
50 W
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Tilt
Textured black
73.958 cm x 21.824 cm x 52.682 cm
8.5 kg
Display Type
Energy Class
Class B
73 kWh
50 W
Diagonal Size
32"
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, SUPER Resolution, Dynamic Power Saving (DPS), 100% sRGB colour gamut, Smart Focus, Low Blue Light Mode, Flicker Free technology, K Locker, Low Blue Light Plus technology, Bright Intelligence (B.I.)
Textured black
73.958 cm x 21.824 cm x 52.682 cm - with stand
8.5 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , DisplayPort , Mini DisplayPort , Headphones , Audio line-in/out
Mechanical
Tilt
Tilt Angle
-5/+15
Backlight Life
30,000 hours
MTBF
60,000 hour(s)
AC 90 - 264 V
70 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Microsoft Windows 7 / 8 / 8.1 / 10
Scroll to top
