BT.com
Wishlist
BenQ EW2750ZL 27" 1920x1080 4ms HDMI LED Monitor with Speakers
BenQ EW2750ZL 27" 1920x1080 4ms...
£192.92
£192.92
Add to wishlist
Delivery
Standard Due date unavailable
BenQ EW2750ZL, the 27 VA LED monitor offers an edge-to-edge slim bezel design that is ideal for high-quality borderless multimedia enjoyment. Furthermore, it is equipped with BenQ's proprietary Flicker-free technology to eliminate flickering at all brightness levels. This effectively reduces eye fatigue to keep less work on your eyes. It's one of the best eye care monitors choices.
BenQ EW2750ZL - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Power Consumption (On mode)
45 W
Panel Type
A-MVA+
Aspect Ratio
Widescreen
Native Resolution
1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D
61.38 cm x 19.49 cm x 45.85 cm
4.3 kg
Microsoft Certification
Compatible with Windows 7
Display Type
Energy Class
Class B
45 W
Diagonal Size
27"
Panel Type
A-MVA+
Aspect Ratio
Widescreen
Native Resolution
1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
Senseye Technology, 72% NTSC colour gamut, Low Blue Light Mode
4.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI-D , 2 x HDMI
Mechanical
Tilt Angle
-5/+20
K-lock security slot, Flicker-free technology
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
£20.60
Scroll to top
