Click to visit BT.com
BT.com
Wishlist
BenQ EW2430 LCD display TFT LED backlight 24" -widescreen-1920 x 1080- speakers- black/metallic
Quicklinx: 7PMGWS00
Mfr#: 9H.L6DLB.QPE
Simple diamond-cut lines reveal the raw beauty and texture of metal chrome. True craftsmanship designs every cut carefully and executes with perfection with mind, BenQ EW2430 delivers functionality and beauty in perfect harmony.
Exclusive Senseye technology, BenQ's answer to the true potential of the human eye in video images - enhances color, clarity and contrast. Its movie mode optimizes deep, rich, and delicate images for the perfect viewing condition.
BenQ EW2430 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Built-in Devices
USB Hub
Aspect Ratio
Widescreen
Native Resolution
Full HD 1920 x 1080 at 205 MHz
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Black with metallic design
57.9 cm x 16.9 cm x 43.3 cm
5.6 kg
Microsoft Certification
Compatible with Windows 7
Display Type
Diagonal Size
24"
Built-in Devices
USB Hub
Aspect Ratio
Widescreen
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye Technology, Advanced Motion Accelerator (AMA) technology
5.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D , VGA , 2 x HDMI , Headphones , 4 x USB downstream , USB upstream ( Type B ) , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
25
Flat Panel Mount Interface
100 x 100 mm
Wall mountable
1 x VGA cable , 1 x USB cable , 1 x audio cable
Power Supply
Internal
65 Watt
