BT.com
Wishlist
BenQ BL912 19" 1280x1084 5ms VGA DVI-D Speakers LED Monitor
BenQ BL912 19" 1280x1084 5ms VGA...
£139.09
Select:
19 in stock
£139.09
Add to wishlist
Delivery
Standard 1-3 working days
Build with the Flicker-free LED backlight panel, the stylish BL912 comes with an ultra-high dynamic contrast ratio of 120,000:1, and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times.
BenQ BL912 - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
41.6 cm x 17.8 cm x 42.45 cm
3.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV GS, GS, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature
HDCP, 72% colour gamut, Senseye 3 Technology, Low Blue Light Mode
41.6 cm x 17.8 cm x 42.45 cm - with stand
3.5 kg
DVI-D (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable , 1 x power cable
Power Supply
Internal
17 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
Without stand - width: 41.6 cm - depth: 6 cm - height: 37.45 cm , With stand - width: 41.6 cm - depth: 17.8 cm - height: 42.45 cm - weight: 3.5 kg
ENERGY STAR Certified
Limited warranty - 3 years - on-site
5 °C
20 - 90%
Accessories
£8.58
£9.51
£16.15
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.61
£9.48
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£46.48
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.61
£62.64
Scroll to top
