BT.com
Wishlist
BenQ BL702A 17" 1280 x 1084 5ms VGA LED Monitor
BenQ BL702A 17" 1280 x 1084 5ms VGA...
£87.50
£87.50
Add to wishlist
Delivery
Standard Due date unavailable
With the BL702A Flicker-free LED backlight panel, an ultra-high dynamic contrast ratio of 120,000:1, and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times. The BenQ BL702A is designed with computer ergonomics in mind to add comfort and flexibility to your everyday work - boosting productivity and efficiency at the same time!
BenQ BL702A - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
36.98 cm x 13.7 cm x 37 cm
2.5 kg
Environmental Standards
ENERGY STAR Qualified
TUV, GS, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
31 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, colour temperature, phase
72% colour gamut, Low Blue Light Mode
36.98 cm x 13.7 cm x 37 cm - with stand
2.5 kg
VGA
Mechanical
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable
Power Supply
Internal
AC 120/230 V
17 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
- weight: 2.5 kg
Limited warranty - replacement - 3 years - on-site
5 °C
20 - 90% (non-condensing)
Scroll to top
