BT.com
Wishlist
BenQ BL3201PT 32" 3840x2160 4ms DVI HDMI DisplayPort USB IPS LED Monitor
BenQ BL3201PT 32" 3840x2160 4ms DVI...
£813.72
£813.72
Add to wishlist
Delivery
Standard Due date unavailable
The BL3201PT, a stunning 32"W display built with IPS technology and the latest 4K2K ultra-high-definition resolution, as a part of its continued effort to support the visual-intensive work required in the fields of CAD/CAM, animation, video editing and graphics arts. So professionals with a meticulous eye for detail can work with perfect precision and achieve high productivity.
BenQ BL3201PT - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
90 kWh
Power Consumption (On mode)
62 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Speakers
Integrated
Display Position Adjustments
Pivot (rotation), swivel, tilt
74.03 cm x 21.34 cm
12.5 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Energy Class
Class C
90 kWh
62 W
Diagonal Size
32"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Senseye 3 Technology, 100% sRGB colour gamut, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Auto Pivot
74.03 cm x 21.34 cm - with stand
12.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
DVI-D (dual link) , 2 x DisplayPort , HDMI , USB , 5 x USB 3.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x SuperSpeed USB cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
TCO Displays 6.0
Power Supply
Internal
79 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Apple MacOS, Microsoft Windows 7, Windows 8, Windows 8.1
Dimensions & Weight Details
Without stand - width: 74.03 cm - depth: 6.56 cm - height: 43.64 cm
Accessories
£7.58
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.64
£41.53
£56.29
Scroll to top
