BT.com
Wishlist
BenQ BL3200PT 32" 2560x1440 4ms DVI-D HDMI DisplayPort Speakers IPS LED Monitor
BenQ BL3200PT 32" 2560x1440 4ms...
£476.18
19 in stock
£476.18
Add to wishlist
Delivery
Standard 1-3 working days
With a 2560 x 1440 WQHD resolution and extra working space mean less scrolls for zooming in and out. Start using BenQ CAD/CAM monitor now and boost your work efficiency! Unique control device docked to the stand of every BL3200PT monitor remotely accesses the OSD menu. Low Blue Light mode, or let you assign your own set of display modes providing ultimate user flexibility. Large screen monitors usually take a noticeable amount of space on the working desk. BL 3200 is designed to save as much of your workspace as possible. Compact stand architecture enables the screen to sit at the very edge of the desk and maximize your working space and comfort.
BenQ BL3200PT - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
75 kWh
Power Consumption (On mode)
51 W
USB 3.0 hub
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Pivot (rotation), swivel, tilt
Black, glossy black
73.9 cm x 23.1 cm x 63.8 cm
13 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class B
75 kWh
51 W
Diagonal Size
32"
Viewable Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Ambient light sensor, HDCP, touch keys, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Dynamic Power Saving (DPS), 100% sRGB colour gamut, Low Blue Light Mode
Black, glossy black
73.9 cm x 23.1 cm x 63.8 cm - with stand
13 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
VGA , DVI , DisplayPort , HDMI , 2 x USB 2.0 downstream , 2 x USB 3.0 , USB 3.0 upstream , USB
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x HDMI cable , 1 x SuperSpeed USB cable
TCO Displays 6.0
Power Supply
Internal
AC 90 - 264 V (50/60 Hz)
97 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 73.9 cm - depth: 23.1 cm - height: 63.8 cm - weight: 13 kg , Without stand - width: 73.9 cm - depth: 23.1 cm - height: 43.7 cm
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Accessories
£9.99
£5.98
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.99
£39.99
£54.98
Scroll to top
