BT.com
Wishlist
BenQ BL2420Z 24" 1920x1080 7ms VGA DVI LED Monitor
BenQ BL2420Z 24" 1920x1080 7ms VGA...
£179.43
12 in stock
£179.43
Add to wishlist
Delivery
Standard 1-3 working days
Tailor-made to improve office worker's health, comfort and work productivity in mind, the BL2420Z boasts a sharp, robust look that calls for solid performance and efficiency. Yet a hollow neck design that keeps cords and cables organized and a base stand featuring a storage tray cleverly balance solemnity with ease of use and comfort. A matte finish further provides users a glare-free viewing experience.
BenQ BL2420Z - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
USB 2.0 hub
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
12 ms (typical); 7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Screen Coating
Anti-glare
Black, non-glossy black
56.32 cm x 23.955 cm x 52.49 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
TCO '06
Display Type
Diagonal Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Video Bandwidth
205 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 5700K
HDCP, Eco-Mode, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Low Blue Light Mode, Flicker Free technology, Auto Pivot, Display Pilot
7 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort , Headphones , Audio line-in , VGA , DVI-D
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable - 1.5 m , 1 x USB cable - 1.5 m
TCO '06
AC 90 - 264 V
23 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS, Microsoft Windows 7, Windows 8
ENERGY STAR Certified
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£41.46
£25.50
£12.10
£21.00
£18.67
£14.31
Scroll to top
