BT.com
Wishlist
BenQ BL2420U 24" 3840x2160 7ms DVI HDMI DP USB LED Monitor Speake
BenQ BL2420U 24" 3840x2160 7ms DVI...
£404.71
£404.71
Add to wishlist
Delivery
Standard Due date unavailable
The BL2420U, 24" 4K ultra-high-definition (UHD) resolution monitor with built-in 100% sRGB, IPS technology and exclusive CAD/CAM, animation and low blue light modes for designers to improve design efficiency.
BenQ Designer BL2420U - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Adaptive Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz, DVI: 30 Hz)
Pixel Pitch
0.136 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (tr - tf); 7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI, DisplayPort
Display Position Adjustments
Black, non-glossy black
56.3 cm x 23.955 cm x 52.49 cm
7.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TCO '06
Display Type
Energy Class
Class C
50 kWh
34 W
Diagonal Size
24"
Viewable Size
23.6"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.136 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
24 - 76 Hz
Horizontal Refresh Rate
30 - 140 kHz
Video Bandwidth
600 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Remote OSD, sRGB colour management, HDCP, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Auto Pivot, animation mode
7.1 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI , 2 x HDMI , DisplayPort , Headphones , Audio line-in , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x DVI cable - 1.5 m , 1 x DisplayPort cable - 1.5 m , 1 x SuperSpeed USB cable - 1.5 m , 1 x audio cable - 1.5 m
TCO '06
AC 120/230 V
58 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Apple MacOS, Microsoft Windows 7, Windows 8
Scroll to top
