BT.com
Wishlist
BenQ BL2411PT 24" 1900x1200 5ms VGA DVI-D DisplayPort Speakers LED Monitor
BenQ BL2411PT 24" 1900x1200 5ms VGA...
£238.69
Select:
More than 50 in stock
£238.69
Add to wishlist
Delivery
Standard 1-3 working days
Ultimate Productivity and Visual Performance
Featuring 16:10 widescreen aspect ratio, 100% sRGB, Flicker-free technology, Senseye® Reading Mode and Eye Protect Sensor, the BL2411PT is tailor made to meet the exceptional screen performance and superb user experience.
Key features
  • 16:10 Aspect Ratio
  • Flicker-free Backlight for Visual Pleasure
  • 24" IPS Wide Viewing Angle Panel
  • Ultra-Flexible Height Adjustment System (HAS)
  • Slim Bezel for Multiple Displays
BenQ BL2411PT - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
44.4 cm x 23.6 cm x 55.5 cm
6.7 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, EN 60950, TUV Ergo, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
24"
Viewable Size
24"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, H/V position, sharpness, input select, colour temperature, phase
HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, 100% sRGB colour gamut, M-book Mode
44.4 cm x 23.6 cm x 55.5 cm - with stand
6.7 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , DisplayPort , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
AC 90 - 264 V
23 Watt
Power Consumption Stand by
0.3 Watt
Limited warranty - 3 years - on-site
5 °C
20 - 90%
Scroll to top
