BT.com
Wishlist
BenQ BL2411PT 24" 1900x1200 5ms DVI VGA DP LED Monitor with Speakers
BenQ BL2411PT 24" 1900x1200 5ms DVI...
£236.11
£236.11
Add to wishlist
Delivery
Standard Due date unavailable
Featuring 16:10 widescreen aspect ratio, 100% sRGB, flicker-free technology, Senseye reading mode and eye protect sensor, the BL2411PT is tailor made is tailor made to meet the exceptional screen performance and superb user experience.
BenQ BL2411PT - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
44.4 cm x 23.6 cm x 55.5 cm
6.7 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, EN 60950, TUV Ergo, ISO 9241-307, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
24"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:10
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, H/V position, sharpness, colour balance, input select, colour temperature
HDCP, Eco-Mode, anti-glare, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology
44.4 cm x 23.6 cm x 55.5 cm - with stand
6.7 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , DisplayPort , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+20
Rotation Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Power Supply
Internal
AC 90 - 264 V
23 Watt
Power Consumption Stand by
0.3 Watt
ENERGY STAR Certified
Limited warranty - on-site - response time: 3 days
5 °C
20 - 90%
Scroll to top
