BT.com
Wishlist
BenQ BL2405PT 24" 1920x1080 2ms HDMI LED Monitor
BenQ BL2405PT 24" 1920x1080 2ms...
£166.92
27 in stock
£166.92
Add to wishlist
Delivery
Standard 1-3 working days
Stable feedback technology prevents the harmful effects of flickering that strain the eyes. Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
BenQ Business BL2405PT - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (tr - tf); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
57.9 cm x 6.3 cm x 35 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 7.0
Display Type
Energy Class
Class A
32 kWh
22 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, 72% NTSC colour gamut, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection
57.9 cm x 6.3 cm x 35 cm - without stand
5.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in/out , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
110 mm
1 x DisplayPort cable - 1.5 m , 1 x VGA cable - 1.5 m
MTBF
60,000 hour(s)
TCO Displays 7.0
AC 120/230 V
33 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm - weight: 5.3 kg , With stand - width: 57.9 cm - depth: 21.3 cm - height: 50.2 cm , With stand - width: 57.9 cm - depth: 21.3 cm - height: 39.2 cm
Scroll to top
