BT.com
Wishlist
BenQ BL2405HT 24" 1920x1080 5ms HDMI DVI VGA LED Monitor with speakers
BenQ BL2405HT 24" 1920x1080 5ms...
£177.76
£177.76
Add to wishlist
Delivery
Standard Due date unavailable
Build with an LED backlight panel, the stylish BL2405HT comes with an ultra-high dynamic contrast ratio of 120,000:1, 16:9 100% dot-to-dot image quality, and BenQ's exclusive Flicker-free technology and Low Blue Light mode to offer you the best viewing quality at all times.
The BenQ BL series is designed with computer ergonomics in mind to add comfort and flexibility to your everyday work - boosting productivity and efficiency at the same time! Designed for business environments, the BenQ BL series of professional monitors is an essential part of your solutions to minimize total cost of ownership and maximize staff productivity - a win-win decision for the benefits of all.
BenQ BL2405HT - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
5 ms (tr - tf); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Height, pivot (rotation), tilt
57.9 cm x 21.3 cm x 50.2 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, ISO 9241-307, TCO Displays 5.2
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, sharpness, colour temperature, phase
HDCP, Senseye 3 Technology, EyeCare Utility, Ultra-Flexible Height Adjustment System (HAS)
57.9 cm x 21.3 cm x 50.2 cm - with stand
5.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , HDMI , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+15
Swivel Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
AC 120/230 V (47 - 63 Hz)
23 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Scroll to top
