BT.com
Wishlist
BenQ 3300 ANSI Lumens XGA DLP Chip Technology Ultra portable 1.9
Delivery
Standard Due date unavailable
Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life- SmartEcoTechnology has perfected what a DLP projector can do. With this innovation, schools and corporates are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation.
BenQ MX528 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3300 ANSI lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
270 Watt
28.3 cm x 22.2 cm x 9.5 cm
1.9 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3300 ANSI lumens
Contrast Ratio
13000:1
Image Size
152 cm - 762 cm
Throw Ratio
1.96 - 2.15:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
sRGB colour profile, ecoFACTS, SmartEco Technology, Dynamic Mode, SmartEco Mode, LampSave Mode
Lens
Lens Aperture
F/2.56-2.8
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Remote control
1 x VGA cable
Nominal Voltage
270 Watt
Power Consumption Stand by
0.5 Watt
28.3 cm
22.2 cm
9.5 cm
1.9 kg
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.75
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.32
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.09
£14.71
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.29
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.30
C2G USB 2.0 To Fast Ethernet Adapter
Quicklinx: 7BBC | In Stock
£24.57
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£31.83
£50.76
Scroll to top
