BT.com
Wishlist
BenQ 2500 Lumens 1080p Resolution DLP Technology Projector
BenQ 2500 Lumens 1080p Resolution...
£1,042.88
£1,042.88
Add to wishlist
Delivery
Standard Due date unavailable
Home entertainment is only a push of a button away! The W1350 living room projector is packed with BenQ's new-generation wireless projection capabilities and side projection feature to give you 100" of 1080p uncompressed Full HD fun wherever and however you like - no complex installations, tangled wires or remodeling costs. Plus, it's as simple to use as any home appliance!
BenQ W1350 DLP projector - 3D
DLP projector - High Definition 1080p
3D Capable
Yes (3D glasses included)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
2500 ANSI lumens
Contrast Ratio
10000:1
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Vertical
Bulb type
260 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
330 Watt
33 cm x 24.7 cm x 11.95 cm
3.68 kg
DLP projector - HD 1080p
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
2500 ANSI lumens
Contrast Ratio
10000:1
Image Size
66 cm - 826 cm
Throw Ratio
1.39 - 2.09:1
Resolution
Full HD - 1920 x 1080 (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
260 Watt
Bulb life cycle
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
DarkChip3 single-chip DLP technology, ISFccc, ecoFACTS, SmartEco Technology, Eco Blank, MHL compliance, NVIDIA 3DTV Play ready
Lens
Lens Aperture
F/2.42-2.97
Zoom Factor
1.5x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Vertical
Vertical Lens Shift
120% / 148%
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x composite video input - RCA , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A
Lens cover, wireless remote control
Power Source
AC
Nominal Voltage
330 Watt
Power Consumption Stand by
0.5 Watt
33 cm
24.7 cm
11.95 cm
3.68 kg
Sound Emission
34 dBA
32 dBA
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.86
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.56
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.75
£15.85
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.50
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£21.84
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.51
£42.69
Scroll to top
