BT.com
Wishlist
BenQ 21.5" VA Monitor GW2270
£108.33
£108.33
Add to wishlist
Delivery
Standard Due date unavailable
The GW2270 VA LED monitor brings viewing pleasure to everyday work and play with exquisite details on the exterior and striking visual performance delivered by 3000:1 high contrast ratio, 178°/178°wide-viewing angle and BenQ's eye-caring design, which consists of BenQ's Flicker-free technology and Low Blue Light modes.
BenQ GW series GW2270 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
50.6 cm x 17.8 cm x 40 cm
3.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Diagonal Size
21.5"
Panel Type
A-MVA+
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode
50.6 cm x 17.8 cm x 40 cm - with stand
3.4 kg
DVI-D , VGA
Mechanical
Tilt
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot, Flicker-free technology
1 x VGA cable - 1.5 m
TCO Displays 6.0
AC 100/120/230 V
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 50.6 cm - depth: 17.8 cm - height: 40 cm - weight: 3.4 kg , Without stand - width: 50.6 cm - depth: 5.1 cm - height: 30.4 cm
ENERGY STAR Certified
Scroll to top
