BT.com
Wishlist
BenQ 2000 Lumens 1080p Resolution DLP Technology Projector
BenQ 2000 Lumens 1080p Resolution...
£630.69
£630.69
Add to wishlist
Delivery
Standard Due date unavailable
Enjoy 1080p Full-HD image projection up to 200" in the comfort of your living room with the W1070 Home Entertainment Projector. You'll be captivated by brilliant image performance featuring a 10,000:1 contrast ratio and a 2000 lumen brightness. Built-in speakers and easy set-up seal the deal on this user-friendly experience.
BenQ W1070 DLP projector - 3D
DLP projector - High Definition 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
2000 lumens
Contrast Ratio
10000:1
Resolution
1920 x 1080
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
335 Watt
31.2 cm x 24.4 cm x 10.9 cm
2.65 kg
DLP projector - HD 1080p
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2000 lumens
Contrast Ratio
10000:1
Image Size
101.6 cm - 596.9 cm
Throw Ratio
1.15 - 1.5:1
Resolution
Full HD - 1920 x 1080
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
240 Watt
Bulb life cycle
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
ISFccc, ecoFACTS, SmartEco Technology, Eco Blank
Lens
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x component video input - RCA x 3 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x serial RS-232 - 9 PIN mini-DIN (management) , 1 x USB - mini-USB Type B (management) , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA
Wireless remote control
Nominal Voltage
335 Watt
Power Consumption Operational (Standby)
0.5 Watt
31.2 cm
24.4 cm
10.9 cm
2.65 kg
Sound Emission
33 dBA
30 dBA
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
