BT.com
Wishlist
Belkin Wireless Dual Band USB Client AC 950/1150
Delivery
Standard Due date unavailable
High speed networking is in your hands when add the Belkin F9L1106az Dual Band USB Wireless Adapter to your home network.
Easy connections
Ideal for watching HD movies or enjoying online gaming, this simple USB adapter plugs into your computer to upgrade its wireless capabilities. Ideal for use with an AC router or high-performance Wireless-N router, this adapter will maximise your internet connection.
With speeds of up to 867 Mbps, you can settle down to a film or browse the internet without limitations and drop-outs. The dual band speeds of 2.4 and 5 GHz make sure that you'll always have a stable connection.
Enjoy all of your favourite online entertainment when you use the Belkin F9L1106az Dual Band USB Wireless Adapter.
Belkin AC Wi-Fi Dual-Band USB Adapter - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
802.11b, 802.11a, 802.11g, 802.11n, 802.11ac
Data Transfer Rate
876 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
876 Mbps
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Scroll to top
