BT.com
Wishlist
Belkin WeMo LED Single Light Bulb Screw - F7C033vfB22
Belkin WeMo LED Single Light Bulb...
£26.72
1 in stock
£26.72
Add to wishlist
Delivery
Standard 3-5 working days
ENJOY WARM, BRIGHT AND ENERGY EFFICIENT LIGHTING
WeMo Smart LED Bulbs give off warm bright light similar to traditional 60-watt incandescent bulbs and only consume 10 watts of energy. In addition, they have a life expectancy of 23 years (based on 3 hours of daily usage), eliminating the need to replace them as often as incandescent bulbs. LED bulbs also give off less heat than traditional light bulbs, which reduces your home's cooling costs.
Designed to work with the WeMo LED Lighting Starter Set
Turn lights on, off or dim individually or as a group -- from anywhere
Create custom schedules and control for your LED lights individually or as a group
Have your smart bulbs turn on a sunset or have them turn off at sunrise
Simulated Occupancy feature turns your lights on and off automatically making it look like you're home - even when you're not.
WeMo Smart LED Bulbs can gradually dim, so you can fall asleep in a more natural way
Modular system. You can add additional WeMo LED Light Bulbs easily, any time
Intuitive, easy set up and easy to use
Works with the entire family of Belkin WeMo products
Free WeMo App for Android, iOS and Kindle operating systems
Works with IFTTT, connecting you to a whole world of Web apps
WeMo works on multiple smart devices simultaneously
WeMo Smart LED Bulbs have a 23 year life expectancy
Bright, warm light similar to a 60W incandescent bulb
Two-year limited warranty
DEVICE COMPATIBILITY
Android smart devices running Android 4.0 or higher
iOS smart devices running iOS 5 or higher
iPod Touch 3rd Generation and later
iPhone 3GS and later
iPad (all models)
iPad Mini
SYSTEM REQUIREMENTS
Belkin WeMo Smart - LED light bulb
Light Bulb Type
LED light bulb
Shape
A19
Socket Type
B22
Wattage
9.5 W
Wattage Equivalent
60 W
Colour of Illumination
Warm white light
Colour Temperature
3000 K
Luminous Power
800 lumens
Beam Angle
240 degree(s)
Dimmable
AC 220 - 240 V
Frequency Required
50 Hz
ZigBee Light Link
Light Bulb
LED light bulb
Shape
A19
Socket Type
B22
Wattage
9.5 W
Wattage Equivalent
60 W
Warm white light
Colour Temperature
3000 K
Luminous Power
800 lumens
Luminous Efficacy
50 lm/W
Beam Angle
240 degree(s)
Dimmable
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 Hz
Warranty
2 years
Scroll to top
