BT.com
Wishlist
Belkin VGA Monitor Replacement Cable
Delivery
Standard 3-5 working days
Designed to interface any PC compatible computer to a VGA or SVGA monitor with HDDB15 female connectors. Featuring 24K gold plated corrosion-proof connectors for maximum conductivity.
Belkin Gold Series VGA cable - 7.5 m
VGA cable
Length
7.5 m
Connector
HD-15 - male
Connector (Second End)
HD-15 - male
Package Type
Retail
VGA cable
Shielding Material
Aluminium
Length
7.5 m
Connector
Package Type
Retail
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent cable!
Reviewed by Matt on 17/06/2007
What can i say. I use this cable to connect my PC to my 50" rear projection tv using D-sub 15-pin to 15-pin. Perfect picture, no latnecy, quality at least ten times that of my old s-video connection. At 7.5m length with these features, you'd be silly to pass it by! BT delivery as always spot on and fast!
2* Vga cable
Reviewed by Nick on 19/01/2006
I brought this cable to connect to my tv. But found it to be very blurry as if you could see double. I then connected it to my comp monitor and got the same.on inspecting the cable against my orignal monitor cable found i found it to have 15 pin holes but only 14 were used up but my original used all 15 pin holes could not explain so i'm gonna return it.
Scroll to top
