BT.com
Wishlist
Belkin Universal Dual USB Car Charger 2x 2.1Amp - Black
Delivery
Standard Due date unavailable
Charge two devices at once, while on the road. The Belkin Dual Car Charger gives you unlimited play and standby time while in the car, and keeps you and a passenger fully charged wherever you go. The low-profile design fits easily in your dash without getting in the way of your other controls. Rubber grips make it easy to insert and remove the Dual Car Charger, and the blue indicator light ring lets you know the charger is fully plugged in and your device is charging.
Belkin car power adapter
Car power adapter
Output Connector Type
2 x USB
Power Device Details
2 x - 4 pin USB Type A - 2.1 A
Apple iPad 2
Car power adapter
Enclosure Colour
Input Connectors
Automobile cigarette lighter
Output connectors
Total 2: 2 x 4 pin USB Type A
Power Provided
20 Watt
Max Electric Current
2.1 A
LED indicator
Apple iPad 2
Scroll to top
