BT.com
Wishlist
Belkin Secure Audio Switch
Delivery
Standard Due date unavailable
The Secure Audio and Microphone Switch can be used to reduce security risks caused by the vulnerabilities of analog signals in a digital environment by reducing the number of exposed microphones that can be exploited by malicious software attacks; reducing security risks caused by user errors when multiple headsets/microphones are preset; eliminating the microphone-switching function from the KVM to isolate it from the USB and PS2 signals; incorporating an external microphone mute button to shut off the microphone when the Switch is not in use or while handling calls where the microphone is not required; preventing the system's mute switch from being manipulated by software or driver with a hardware mute switch.
Belkin Secure Audio and Microphone Switch - audio switch - 4 ports - B2B
Audio switch - 4 ports
Subtype
Audio
Ports
4 x audio
AC 120/230 V
27.69 cm x 8.64 cm x 3.3 cm
0.75 kg
Manufacturer Selling Program
Belkin B2B
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
Audio
Ports
4 x audio
Status Indicators
Port status
4 x audio output - mini-jack , 4 x microphone input - mini-jack , 1 x microphone input - mini-jack , 1 x audio output - mini-jack
External power adapter
AC 120/230 V
Belkin B2B
27.69 cm
8.64 cm
3.3 cm
0.75 kg
Limited warranty - 3 years
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Scroll to top
