BT.com
Wishlist
Belkin PRO Series - USB Extension Cable - USB (M) to USB (F) - 1.8m - Moulded
Delivery
Standard 3-5 working days
Our Belkin USB Extension Cable extends your existing USB device cable by six feet. With this handy Cable, you’ll never have to struggle with cables that are too short while connecting your printer, scanner, drive, or adapter. Molded-strain relief construction and PVC overmolding ensure a lifetime of error-free transmissions and our Flextec cable jacket is flexible for use in tight areas.
Belkin PRO Series USB extension cable - 1.8 m
USB extension cable
Shielded
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB extension cable
Shielded
Plated Connector
Gold
Molded
Length
1.8 m
Connector
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Cheap but good
Reviewed by on 05/11/2005
Before ordering this USB extension cable I popped into PC World to see what they had to offer, I was surprised to find a similar item but they wanted £18 for it.......what a rip-off. Well done BT, under £2 for this cable is exellent.
5* ext cable
Reviewed by blip on 29/12/2005
its an extension cable does what the discription says
Scroll to top
