BT.com
Wishlist
Belkin N300 Wireless Router DSL
Delivery
Standard Due date unavailable
Better Wi-Fi performance to browse the Web wirelessly
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you powerful signal strength and maximum coverage, while minimizing dead spots--so you can connect from virtually anywhere in your home.
Speed
The N300 provides wireless speeds of up to 300Mbps*--ideal for surfing, emailing and instant messaging.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're out of the box and onto the Web.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
+1 App
Enhance your online activities with Belkin's integrated SELF-HEALING app.
*The standard transmission rates--300Mbps, 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
Belkin F9K1002 - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Connection / user qty: 16
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP, HTTPS
NAT support, Stateful Packet Inspection (SPI), firmware upgradable, MIMO technology, Wi-Fi Protected Setup (WPS), reset button, MultiBeam technology
Microsoft Certification
Compatible with Windows 7
Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Apple MacOS X 10.5, Microsoft Windows Vista / 7
United Kingdom
2 years warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA2
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, ICES-003 Class B, RSS-210, FCC Part 15, RSS-139
Status Indicators
Status
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities, Self-Healing
System Requirements Details
Windows XP/Vista/7 - 1 GHz - RAM 512 MB - HD 600 MB , MacOS X 10.5 - 1 GHz - RAM 512 MB - HD 600 MB
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Scroll to top
