Click to visit BT.com
BT.com
Wishlist
Belkin N150 Wireless Modem Router ADSL
Quicklinx: 7XQCWS00
Mfr#: F9J1001UK
Connect to the Internet securely in three easy steps with the Belkin Surf Wireless Modem Router. Featuring a built-in ADSL 2+ modem in addition to Wireless-N technology, this router will give you speeds of up to 150 Mbps on Wireless-N networks, letting you surf the web, email, and instant message from anywhere in your home. With "easy start" and preconfigured WPA/WPA2 and WEP encryption settings, your network will be up and running securely in just a few minutes.
Belkin SURF F9J1001 - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Connection / user qty : 16
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP, HTTPS
NAT support, Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS), MultiBeam technology
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5 - 10.6, Microsoft Windows 7 (32/64 bits)
United Kingdom
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Routing Protocol
Static IP routing
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, 256-bit WPA, WPA2
Authentication Method
Radio Service Set ID (SSID)
Status Indicators
Status
Communications
DSL modem
ADSL
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x ADSL - RJ-11
Aerial
Aerial
Internal
External power adapter
1 x network cable , 1 x modem cable
United Kingdom
Software Included
Drivers & Utilities
2 years warranty
Service & Support Details
10 - 85% (non-condensing)
