BT.com
Wishlist
Belkin MIX IT Lightning Sync/Charge Cable 1.2m - Blue
Belkin MIX IT Lightning Sync/Charge...
£17.84
37 in stock
£17.84
Add to wishlist
Delivery
Standard 3-5 working days
Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPod touch (5th generation) iPad with Retina Display (4th generation), or iPad mini at the fastest possible speed. The smaller, more durable Lightning connector is also reversible, which makes plugging it in easier than ever.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere. Great as a replacement cable or if you simply need an extra.
Belkin MIXIT Lightning to USB ChargeSync - Lightning cable - Lightning / USB - 1.2 m
Cable
Length
1.2 m
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Apple iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
1.2 m
Sync and charge
Blue
Connector
Apple Lightning - male
4 pin USB Type A - male
Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus , Apple iPod nano (7G) , Apple iPod touch (5G)
Scroll to top
