BT.com
Wishlist
Belkin Flat 2.4amp Lightning Sync charge cable for Apple items - Red
Delivery
Standard Due date unavailable
Charge and sync all your Lightning connector devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the 4-foot Lightning to USB cable to charge your iPhone 5, iPad mini, iPad Air, iPad (4th generation) or iPod Touch (5th generation) at fast speeds. Its flat, ultra-flexible design makes it easy to stash without getting tangled.
Plug it into your laptop to charge and sync, or use your own wall/car charger with USB port to charge from anywhere.
Belkin MIXIT Flat Lightning to USB Cable - Lightning cable - Lightning / USB 2.0 - 1.22 m
Cable
Length
1.22 m
Connector
Lightning - male
Connector (Second End)
USB - male
Flat
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable - flat
Interface Supported
Lightning / USB 2.0
Length
1.22 m
Red
Connector
Apple Lightning - male
4 pin USB Type A - male
MFI
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus , Apple iPod nano (7G) , Apple iPod touch (5G)
Scroll to top
