BT.com
Wishlist
Belkin FASTFIT Ultra Slim Bluetooth Keyboard in Black for iPad 2, 3 & 4 (Retina)
Delivery
Standard Due date unavailable
FastFit iPad Case with Cover - iPad 2, 3 & 4
Type Faster with TruType Keys
This laptop-style TruType keyboard has well-spaced keys that promote typing accuracy. Each key has a spring mechanism that provides tactile feedback when struck, enabling fast, intuitive, and comfortable typing.
Snaps On for Secure Protection
The cover is ideal for travel or typing on the go. Simply snap your iPad into the frame--secure-hold magnets will keep it in place.
Two Viewing Angles
The cover features two rails, so you can adjust the angle of your iPad for comfortable typing or media watching. The cover supports both landscape and portrait orientations.
Sleek, Low-Profile Protection
With a snug fit and smooth inner lining, this cover helps protect your iPad from scratches, scuffs, and other types of wear.
Bluetooth Connectivity
To use the keyboard with your iPad, simply switch it on, pair it with your iPad, and it will connect via Bluetooth. The keyboard will stay charged for up to 60 hours active battery life and up to 2,000 hours standby battery life. It can be recharged with the included USB cable.
Designed for iPad 2 / 3rd / 4th Generations
Not only does the cover feature AutoWake magnets that turn the iPad on when the cover is opened, but it also has iPad-specific shortcut keys that allow you to adjust volume, control your music, and copy and paste text.
Package Includes:
- Belkin FastFit Keyboard Cover for iPad
- USB charging cable
- User manual
Compatibility
iPad 4th gen
iPad 3rd gen
iPad 2
Belkin FastFit - keyboard - QWERTY
Keyboard
Bluetooth
Layout
QWERTY
Hot Keys Function
Multimedia, volume, copy, paste
TruType keys, 2 stage tilt angle stand
Black, white
Apple iPad (3rd generation); iPad 2; iPad with Retina display (4th generation)
Keyboard
Bluetooth
Input Device
Hot Keys Function
Layout
QWERTY
Black, white
Cover
1 x USB charge cable
Apple iPad (3rd generation) , Apple iPad 2 , Apple iPad with Retina display (4th generation)
Scroll to top
