BT.com
Wishlist
Belkin F9K1015UK N300 Range Extender
Delivery
Standard Due date unavailable
With the Belkin Wi-Fi Range Extender, you can expand your home network's wireless connection up to an additional 5000 square feet. It's incredibly simple to install and is compatible with virtually any router, so there's no need to reconfigure anything on your home wireless network. It's the fast, easy way to expand your home wireless connection.
There's no complex setup with the Wi-Fi Range Extender. Just plug it in, find your home network, and you'll enjoy expanded wireless in minutes. Simple Start installation means you can connect the Wi-Fi Range Extender from your from your Wi-Fi mobile devices such as tablets and smartphones, as well as your PC or laptop.
Belkin N300 Wi-Fi Range Extender - Wi-Fi range extender
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Microsoft Windows XP SP3 or later, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
2 years warranty
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, 256-bit WPA, WPA, WPA2
IEEE 802.11b, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
Internal
1 x 100Base-TX - RJ-45
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent bit of kit!
Reviewed by Anonymous on 30/06/2014
I have BT Infinity with the new router but the wireless is still poor through brick and gives me little signal in the garden. Got this, installed in minutes (it really is simple) and had 4 bars of full strength wireless in the garden! No messing, no drop outs (so far) and I'd say over 15m of coverage! Outstanding value and it is as tiny as it looks, leaves room for my other socket to have something plugged in too!
Scroll to top
