BT.com
Wishlist
Belkin E-Series PS/2 Cable Kit 1.8m
Belkin E-Series PS/2 Cable Kit...
£6.67
7 in stock
£6.67
Add to wishlist
Delivery
Standard 3-5 working days
The OmniViewT All-In-One Universal KVM Cable Kit is the easiest and neatest way to connect all your computers and servers to your KVM switches. These Cable Kits offer high-performance, high quality, and reliability. The All-In-One Universal KVM Cable Kit features nickel-plated connectors and are great for high-resolution applications. The coaxial cabling eliminates picture "ghosting" and fuzzy images, and the ferrite beads on each end of the cable provide superior EMI interference protection. Each cable features two male PS/2 and one male VGA connector on each end. The OmniViewT All-In-One KVM Universal Cable Kit is available in a wide range of lengths from 6 to 35 feet.
-Strain relief molding increases durability
-Ferrite Bead reduces electromagnetic and radio frequency interference (EMI/RFI)
-Double shielding and PVC over-molding prevent loss of data
-PC99 color and modified thumbscrews allows for easy installation
-All-In-One design makes connections and setups neat and easy
-Coaxial VGA cabling supports superior image clarity
-UL rated wiring
Belkin E Series Cable Kit for PS/2 - keyboard / video / mouse (KVM) cable - 1.8 m
Keyboard / video / mouse (KVM) cable
Length
1.8 m
Connectors
Connectors (Second End)
15 pin HD D-Sub (HD-15) - male , 2 x 6 pin mini-DIN (PS/2 style) - male
OmniView E Series 2 Port KVM Switch, 4 Port KVM Switch
Length
1.8 m
Connectors
Belkin OmniView E Series 2 Port KVM Switch, 4 Port KVM Switch
Scroll to top
