BT.com
Wishlist
Belkin Conserve Switch Energy Saving Surge Strip with Remote
Delivery
Standard Due date unavailable
Save Energy with a Single Click
Conserve Switch™ Surge Protector with Remote
  • Control power to your computer system
  • Wireless remote works up to 60 feet away
  • Reduce standby power
Control standby power to your whole computer system.
Your computer system components use energy around the clock, even when they're not in use, wasting energy and driving up your electric bill. The Conserve Switch Surge Protector with Remote lets you shut off power--including standby power--to all your computer system components with a single click.
One-click control.
The wireless remote controls six Remote-Switched outlets for all your peripherals--your monitor, printer, external hard drives, speakers and more. Two Always-On outlets stay on for devices that need continuous power, like your wireless router or cordless phone. Place the remote on your desk or shelf, or mount it on the wall, for the convenient way to save energy.
  • 8 total outlets
  • Wireless remote switch works up to 60 feet away and is wall-mountable (battery included)
  • Remote-Switched Outlets let you eliminate standby power to up to 6 outlets with one click
  • 2 Always-On Outlets for devices that need continuous power, like routers
  • Cable-management clip keeps cords neat
  • Sliding safety covers for added protection
  • 2-Year Limited Warranty
  • £100,000 Connected Equipment Warranty
Belkin Conserve Switch - surge protector
Surge protector - external
0.76 kg
Input Connectors
1
Remote control
10.2 cm x 33 cm x 3.8 cm
Grey, white
Input Connectors
1
Surge Suppression
Surge Response Time
1 ns
Surge Energy Rating
1000 Joules
Clamping Level
400 V
Max Spike Current
72000 A
Circuit Protection
Circuit breaker
Remote control
Power cable - integrated - 1.2 m
Overload protection, cable management
10.2 cm
33 cm
3.8 cm
0.76 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Ideal for everyone
Reviewed by Beak on 16/10/2013
Easy to "setup" and install. Adjust the dip switches if you want them to all operate from one switch or separately. Have 2 in the lounge on one switch, and two in the Study on a separate switch. Lets save some electricity! :)
5* Works really well..
Reviewed by Paul on 17/07/2013
Easy to use , plug your items in , when you've finished , turn off the power switch from anywhere nearby (mines by the door on the other side of the room so I can turn it all off last thing at night) and everything plugged in on the switchable side of the switch gets 'unplugged'.
No more forgetting and leaving it all on standby.
1* Avoid Like the Plague
Reviewed by Karl on 27/12/2013
Bought and delivered in reasonable time considering its Christmas and all but doesn't actually work...the on switch works consistently but cannot turn off, after researching further it's clear that this product is extremely unreliable and many buyers are experiencing similar problems.
Shame for such a good product concept but disappointing final product...kinda ironic that it's meant to save you money, but instead it's a waste of yours!
Scroll to top
