BT.com
Wishlist
Belkin Cinema Stripe Cover for iPad mini 3 - Purple
Delivery
Standard Due date unavailable
Elevate your tablet experience with the Stripe Cover for the iPad mini. They've given one of the best-selling favorites a makeover - with the same durable construction and thoughtful design details now in a fresh look.
The Belkin Stripe Cover for the iPad mini is designed first and foremost to keep your iPad mini safe and secure. The frame is designed with protective corners made of a flexible silicone that gently lock your iPad mini into place. When you close the front cover, a soft inner lining keeps your screen safe from scratches.
Rubberized feet on the frame and a grip suede inner lining prevent your device from slipping and allow you to position your iPad mini at the angle that suits you best. They've also improved the experience of using your touchscreen in the viewing position by integrating a hinge stop into the stand so your screen stays steady while you're typing, swiping or navigating.
The Stripe iPad mini Cover case also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen.
The Belkin Stripe Cover iPad mini case is made of a durable material with a pinstripe down the front that adds a hint of contrasting color and touchable texture. It's then molded to the shape of your iPad mini for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned.
The Stripe iPad mini Cover features an integrated magnet that keeps the front cover closed when you're on the go.
The Belkin Stripe Cover iPad mini case is designed so that the camera, ports and speakers are fully exposed, so you can quickly and easily snap a photo, adjust your volume, plug in your headphones, and connect your charging cable while keeping your case on and your tablet fully protected.
Belkin Stripe Cover flip cover for tablet
Flip cover for tablet
Plum
Apple iPad mini; iPad mini 2; 3
Plum
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Scratch-resistant
Cover Type
Flip cover
Closure Type
Magnetic closure
Camera lens cutout, microfibre lined, adjustable viewing angles, soft inner lining, suede inner lining
Cover Features
Stand function
Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3
Scroll to top
