BT.com
Wishlist
Belkin Car Charger - Lightning connector - iPad mini/iPhone 5/iPad 4th Gen (with Retina Display)
Delivery
Standard 3-5 working days
Car Charger 2.1 AMP For iPhone 5, iPad mini, iPad 4th gen
Small but Powerful
It's here -- the car charger designed exclusively for the iPhone 5. Get unlimited play and standby time with the low-profile design that sits flush in your dash.
Charge at the Speed of Lightning
Charge your iPhone 5, iPad mini or iPad with Retina Display (4th generation) at the fastest possible speed with the smaller, more durable Lightning connector. It's reversible, which makes plugging it in easier than ever.
Know You're Charging
Green indicator light easy to see your device is charging.
Small, Compact and Easy to Insert and Remove
Low profile design fits easily in your dash. Rubber grips allows you to insert and remove your lightning car charger with ease.
Features:
-Ultra-compact
-Plugs into any car power outlet
-2.1 Amp/10 Watts
-4' cable with reversible Lightning connector
COMPATIBILITY
iPad mini
iPhone 5
iPod nano 7th gen
iPod touch 5th gen
iPad 4th gen
Belkin Car Charger car power adapter
Car power adapter
Output Connector Type
Lightning
Cables
iPhone / iPad charging cable - 1.2 m
Apple iPad mini; iPad with Retina display (4th generation); iPhone 5
Car power adapter
Enclosure Colour
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Output connectors
Apple Lightning
Power Provided
10 Watt
Max Electric Current
2.1 A
Apple iPad mini , Apple iPad with Retina display (4th generation) , Apple iPhone 5
Scroll to top
