BT.com
Wishlist
Belkin Advanced Secure DVI-I KVM Switch; 2-Port
Belkin Advanced Secure DVI-I KVM...
£314.25
Hurry, only 1 left in stock!
£314.25
Add to wishlist
Delivery
Standard 1-3 working days
Belkin's Advanced Secure DVI-I KVM Switch offers superior security and data protection by providing true data path isolation between systems and networks. It is fully compatible with legacy and new government systems and exceeds NIAP security requirements. Using uni-directional data paths with optical diodes, it prevents peripherals from being used to leak information from one computer system to another. Additional security is provided through its end-to-end tamper-proof system that prevents physical tampering, and its intuitive user interface reduces user-switching errors by providing clear identification. Expect the best compatibility out-of-the-gate with a Secure KVM solution that's designed and vigorously tested to work seamlessly with common systems and peripherals used by the defense and intelligence community.
Dedicated processors with emulators for every port:
Isolated port paths for video, audio, peripherals, and smart card readers prevent data leaks between computers.
Unidirectional data paths:
Optical data diodes prevent peripherals from being used to breach systems.
Display security:
Protected display interface prevents data leakage via the monitor.
Peripheral management:
USB device detection prevents unauthorized peripheral usage.
Anti-tampering:
Internal electrical sensors render unit inoperable if opened.
Multi-platform support:
Supports cross-platform systems, including DVI-D, DVI-I, VGA video interface technologies with Belkin Smart Cables.
Uni-body chassis:
Minimizes entry points and prevents physical tampering.
Secure labelling:
Holographic tamper-evident product label provides visual indication and prevention of tampering.
Customizable port coloring and naming:
Facilitates port identification and reduces user switching errors.
Fast switching:
No keyboard or mouse delays when switching ports.
Intelligent common access card (CAC) switching:
Prevents unwanted system log-off while switching ports (available on certain models).
Easy mounting:
Uses an integrated mounting track to allow under-desk or side-wall mounting, creating extra desk space.
High retention connectors:
Semi-locking USB ports prevent accidental disconnection.
Secure packaging:
Tamper-evident packaging ensures product is not tampered with during transport.
Multi-monitor support:
Connects two monitors for each system (for certain models) to increase user productivity.
Belkin Advanced Secure DVI-I KVM Switch - KVM / audio switch - 2 ports
KVM / audio switch - 2 ports - PS/2, USB
Subtype
KVM
Ports
2 x KVM / audio
KVM Users Qty
1 local user
Temperature sensor
31.8 cm x 4.3 cm x 16.3 cm
1.7 kg
Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7, Red Hat Enterprise Linux Desktop
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
2560 x 1600 @ 60 Hz
Temperature sensor
Status Indicators
Port status
2 x DVI-I (dual link) , 4 x USB - Type B , 2 x keyboard (PS/2) / mouse (PS/2) , 2 x audio - mini-jack , 3 x USB - Type A
External power adapter
EAL 2
31.8 cm
4.3 cm
16.3 cm
1.7 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Scroll to top
