BT.com
Wishlist
Belkin Advanced Secure DVI-I KVM Switch - 4 ports - Desktop
Belkin Advanced Secure DVI-I KVM...
£396.63
£396.63
Add to wishlist
Delivery
Standard Due date unavailable
Belkin's Advanced Secure DVI-I KVM Switch offers superior security and data protection by providing true data path isolation between systems and networks. It is fully compatible with legacy and new government systems and exceeds NIAP security requirements. Using uni-directional data paths with optical diodes, it prevents peripherals from being used to leak information from one computer system to another. Additional security is provided through its end-to-end tamper-proof system that prevents physical tampering, and its intuitive user interface reduces user-switching errors by providing clear identification. Expect the best compatibility out-of-the-gate with a Secure KVM solution that's designed and vigorously tested to work seamlessly with common systems and peripherals used by the defense and intelligence community. Models F1DN102C and F1DN104C feature support for a peripheral CAC reader.
Belkin Advanced Secure DVI-I KVM Switch - KVM / audio switch - 4 ports
KVM / audio switch - 4 ports - PS/2, USB
Subtype
KVM
Ports
4 x KVM / audio
KVM Users Qty
1 local user
Temperature sensor
31.8 cm x 4.3 cm x 16.3 cm
1.8 kg
Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7, Red Hat Enterprise Linux Desktop
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
2560 x 1600 @ 60 Hz
Temperature sensor
Status Indicators
Port status
4 x DVI-I (dual link) , 8 x USB - Type B , 2 x keyboard (PS/2) / mouse (PS/2) , 4 x audio - mini-jack , 3 x USB - Type A
External power adapter
EAL 2
31.8 cm
4.3 cm
16.3 cm
1.8 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Scroll to top
